D DavieA TF Feb 27, 2010 #11 Quick question Dave whats the difference in causes between cracks all over joint or along the edges of tiles?
D DavieA TF Feb 27, 2010 #12 Tried grouting over the hairline cracks but they re appeared, Any idea or you still recon best bets to take out damaged grout and try again?
D DHTiling Feb 27, 2010 #13 It is was all over the grout.. It could be bad batch or incorrect mix or even bad delfection to break up that easy. When it is cracks on the tile edge, it is more likely small deflection from being walked on or moisture absorption from the tiles biscuit. But not something i have come across wi th mapei grouts.. i have with BAL stuff but not ultra colour.
D DHTiling Feb 27, 2010 #14 DavieA said: Tried grouting over the hairline cracks but they re appeared, Any idea or you still recon best bets to take out damaged grout and try again? Click to expand... I didn't mean grout over, i meant just rake that area out and re-grout that bit.
kilty55 TF Arms Feb 27, 2010 #15 just out of interest mate what was the adhesive type you used? only ask as i saw a similar issue recently
D DavieA TF Feb 27, 2010 #16 Ok Ill remove damaged grout areas and re grout, Thanks. I take it grouting over cracked doesnt work!! ??
D DavieA TF Feb 27, 2010 #17 Alright Kilty, It was mapei keraflex. Usually good stuff and have had no issues. What was your outcome??
D DHTiling Feb 27, 2010 #18 DavieA said: Ok Ill remove damaged grout areas and re grout, Thanks. I take it grouting over cracked doesnt work!! ?? Click to expand... Not really davie.. you ned more width to get a grab.
