Help... is this the right way to tile my bathroom?
bunnycd
Would really like some advice peeps ***
I had an unfortunate experience with a tiler (I dont think he was one really) I employed this guy to tile my bathroom, he put the tiles on with unibond with 5 dabs and it never bonded after 48 hours the tiles started to fall off from a great height, one even smashed near my babies head so after that I was scared and sacked him and I took the decision to find someone else.
Now, the new guy has said he has 30 years experience and I have followed up his reference but I am a bit worried, he said that my walls are not good enough to tile straight onto and recommended that he puts plasterboard on the walls prior to tiling, is this the right thing to do? I have included photos of my bathroom below but wanted to know what you think? Is there anything I should look out for, is putting plasterboard all over the walls before tiling the right way to go? He also said the wall above bathroom needs plasterboard but this looks ok to me, what do you think?:
If you was going to reboard on top of the tray plasterboard would not be my first choice, any moisture getting thru to the board would be sucked up like a sponge into the gypsum core.
You shouldn't need to take the tray out. the board ideally should sit on top of the tray, allowing enough room for the tile and adhesive width for the shower screen to fit properly. If you can if you replace the boards, put new noggins agianst the tray as this will firm up the tray and support the bottom of the boards. Use waterproof tape between the boards and the shower tray.
Many guys here a using Marmox boards as they are waterproof, and only need waterproof tape at the joints, it is much lighter and easier to cut.
Bathroom Tiling Advice
Unsolved
bunnycd,
bugs183,
bunnycd,
bugs183,
