connors12345
how easy is it??? can i just dot and dab it to the wall or will it have to be screwed.... the walls are not plaster board
even if there skimmed mate doesn't mean to say there going to be sound, Unless they get a good plasterer to use guide pins and make flat as pancake. Plaster boarded would be a lot faster and a lot stronger also you would tile it quicker.
Good advice proper job and as you say not all plasterers use this technique hence the walls still not being flat.even if there skimmed mate doesn't mean to say there going to be sound, Unless they get a good plasterer to use guide pins and make flat as pancake. Plaster boarded would be a lot faster and a lot stronger also you would tile it quicker.
would you trust dot and dab onto poo walls
good advice which is especially true if you dont get the levels straight around windows when d&d ing.Tiles will jut out making the job look s h i t e.If the wall's are hollow I would take the lot off and dry line, To dry line on to existing wall's you are bringing the wall surface out quite a bit, Also with dab's of adhesive for the board's don't make the addy to thin or push the board's to tight to the existing wall otherwise it will be next to useless.
