Help! SLC fail - Self levelling compound failed Pro 50
Hi,
jackonboards spec is to screw down to timber at 300mm intervals, so that's what I do.
I find if I were to glue instead/aswel there is additional cost of time, primer, adhesive, also raised flooring height.
im not saying glueing is wrong, it's just not something that I do.
They say not to stick down, just to screw using the washers. I use adhesive and screws (next day) on insulation boards.
Don't think this is your problem though.
Just read that. It does say you have to use adhesive and screws. But using Marmox boards you can just use screws. I have always stuck and screwed, it seems better.
I must say, that's not the literature that I have read! But very interesting, and I will adjust accordingly. Thank you.
i believe dukka and marmox are recommended screw only aswel.
learn something new everyday..
Afraid not guys.... Marmox is almost identical to jackoboard and instruct to glue also.... Broken Link Removed
Sorry, don't mean to hijack the thread! I agree with thermal shock also. Hope the stat tells all!
Marmox instructions there say screw every 300mm, doesn't say anything about adhesive.
But does offer 2 different ways of fixing. Adhesive of screw
there you go :
Assembly information
JACKOBOARD Construction board for floor use
Special sealing tape (e.g. JACKOBOARD sealing tape) should be used to reinforce the board
joints in wet areas. In addition, care must be taken to seal any penetrations in the construction
board, e.g. for pipes or screws and anchors, using suitable sealing agents.
We recommend covering the entire construction board surface with an additional layer of
reinforcement weave.
The construction boards must not be reinforced until the thin-bed mortar used to bond the
construction boards to the substrate is completely dry.
Use on wooden substrates
The construction boards can only be installed on substrates that are similar to timber formwork.
Installation on a substrate that is only planked is not recommended.
Suitable adhesives, applied with a notched trowel, are used to glue the entire surface of the
JACKOBOARD construction board (min. thickness: 10 mm) to the wooden substrate. The
entire surface of the JACKOBOARD construction board is bedded firmly in the adhesive by
gently pushing it back and forth. The construction boards should be laid with staggered joints.
Once the adhesive bonding of the construction board to the timber formwork is completely dry,
the construction boards must be additionally fastened using wooden screws and insulation board
discs (e.g. JACKOBOARD stainless steel insulation board discs). At least 5 screws are needed for
each m2 and they must be screwed to a depth of at least 20 mm into the timber structure. The
screws should be spaced at least 30 mm from the edge of the construction board. The screws
must be tightened until the head is flush with the surface. The construction board can be slightly
indented with a hammer before fastening the screws to ensure that the insulation board discs do
not protrude above the surface of the construction board.
All construction board joints must be reinforced with an alkaline-resistant fibre glass weave
(e.g. JACKOBOARD glass fibre tape) with a minimum thickness of 120 mm.
We recommend reinforcing the entire construction board surface with an additional layer of
protective weave when installing on wooden substrates.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
