Discuss Help.... The dreaded 6mm ply in the Canada Tile Advice area at TilersForums.com.
mbcmultitrade
I have just tiled a bathroom floor which comprised of 6mm ply, over t&g chipboard flooring, - which then had an UFH coil taped to the ply. I reluctantly tiled onto the ply and consequently the adhesive has failed. The griut has cracked and there is movement on the corners of the tiles (60x30)
I was sure there was no real deflection in the original floor, and I assumed tiling onto the 6mm ply would be sufficient, despite hearing the odd horror story re the dreaded 6 mm ply.
Yes - I was wrong.
Can someone explain to me why you should not tile onto 6mm ply and how/why it fails the tiles/adhesive.
Also. Moving forward, Can I now remove the tiles and use a flexible SLC on top and then re-tile, or do I have to rip up the ply & UFH and start again with Hardi backer?
Your advice and 'told you so's' greatly appreciated.
P.s
I used Nicobond Quick flex ady and primed the ply twice with Nicobond acrylic primer.
Concrete guy
Fundamentally, there was too much movement (flexing) in the substrate as it hadn't been reinforced sufficiently.
That really is the top and bottom of it.
A thicker ply or suitable backer board screwed down would have reduced movement, cracking, flexing.
There are some that would also incorporate an uncoupling membrane such as Ditra Matting on top of the reinforcement. On a small bathroom floor I feel that's overkill - but some tilers will require it.
im sorry but you might as well have put cardboard down,you are right you will have to take the flack now ,why not stick to what you know ,whatever that may be hopefully you will now have learnt a lesson ,that is we are called TILERS because that is what we do ,maybe lesson learned hopefully, rant over :mad2:
bugs183
It could have been worse MB, you could have said you used PVA, tubbed tile on to wood adhesive, lash clips and you turned the heating on to dry out the adhesive! Well done for putting hands up though!
Yea matey as the guys say it needs all ripping up, no amount of flexible adhesive will absorb any deflection in the timber.
Reply to Help.... The dreaded 6mm ply in the Canada Tile Advice area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
We just had a 1.5 sq. m area of floor tiled professionally in our ensuite. The base floor is 18...
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
Hi All, im after some advice on flooring if i may. What i am planning on doing is removing the...
Perfect Tiling
    Votes: 9 6.3%
    Votes: 13 9.1%
    Votes: 9 6.3%
    Votes: 43 30.1%
    Votes: 17 11.9%
    Votes: 34 23.8%
    Votes: 3 2.1%
    Votes: 20 14.0%
    Votes: 18 12.6%
    Votes: 15 10.5%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
