Discuss Help.... The dreaded 6mm ply in the Canada Tile Advice area at TilersForums.com.
Moving forward, Can I now remove the tiles and use a flexible SLC on top and then re-tile, or do I have to rip up the ply & UFH and start again with Hardi backer?
So you're still tempted to keep the ply though, hoping that it'll be better 2nd time round? I think we should pass this one onto a good local Tiler to sort out. And if he's good, stick with him & use him for any future tiling projects
mbcmultitrade
Thanks for all of your angry comments and advice. I hold my hands up, i know I've cocked it up, - I just want to do the right thing in getting it right. I have been tiling a few years now, and never tiled onto 6mm ply before until this occasion. I did it this time round though, as I took advice the builder on site who had said they had been doing it for years and had never had a problem.
Thanks to ATSdiamondtools for the only piece of helpful advice in this thread :)
AliGage
Subscribed
4,531
1,188
Peterborough, England
I think my van has a bit of a problem. Might get the paperboy to fix it for me.
Had you asked the questions before you cocked up someone's home im sure you would have got plenty of useful advice from the professional tilers that are members of this forum.
Marksmithtiling
AAHH that old chestnut,took the advice of the BUILDER, been doing it for years not a problem !!!!!!!!:mad2:
I
ian158
But you been a member since 2012...in all that time you must of seen a thread on lines of, don't use ply, use cement board....and you took the builders advice !..having said all that i took a tiled floor up that had been laid on 6mm ply which had been tacked with brass tacks to t/g floor boards...it was one of the hardest floors i have ever taken up..the tiles would not seperate from the ply...had to get a shovel and lift the ply up with tiles attached..been down more that 20 years and would have been fine for another 20 !..
Concrete guy
Ok , I think it's safe to say the guy has held his hands up and has taken three pages of flack for it.
Give him the specs on how it should be done correctly so he can rectify this job (if the customer wants) and won't make the same mistakes in the future.
Any potential new members or guests reading this thread will probably not fancy joining on the grounds it's a really hostile place here.
Reply to Help.... The dreaded 6mm ply in the Canada Tile Advice area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
We just had a 1.5 sq. m area of floor tiled professionally in our ensuite. The base floor is 18...
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
Hi All, im after some advice on flooring if i may. What i am planning on doing is removing the...
Perfect Tiling
    Votes: 6 4.5%
    Votes: 11 8.3%
    Votes: 8 6.1%
    Votes: 38 28.8%
    Votes: 16 12.1%
    Votes: 32 24.2%
    Votes: 3 2.3%
    Votes: 2 1.5%
    Votes: 19 14.4%
    Votes: 18 13.6%
    Votes: 15 11.4%
    Votes: 7 5.3%
    Votes: 3 2.3%
    Votes: 2 1.5%
