Herringbone Floor Tiling Set Out
One sides 450 i think the other side is 300 but i would imagine i can get the same result using it what you think 3?
Hahaha ok Ash think we must be talking cross terms here.
U asked where u could get a 90 degree set square yes?
Then u said u had a 45 degree square and could u use that, yes?
Yep, and i can see where i went wrong lol as u can tell mate im not good with angles something i need to get to grips with i think lol
i cant get my head round it i want to do it like ali has done in that pic just without the boarder, but all need is the 45 degree of the triangle dont i?
Buy a simple carpenters square Ash.
Use the 45 degree on it to mark a line a 45 degrees from the corner of a tile. Do this on a few. Find a centre line and lay the tiles to it so the centre line follows through the line on your tile.
If that makes sense
If that makes sense
I cant picture it ali i should be ok been looking at some of the work so as long as i square up the room to the mm i should be ok with it
Not doing the job yet anyway just pricing and seing if it is do-able first but wanted to know how to set it out incase i get some samples
Mr Tiler,
kevsalt,
Mr Tiler,
kevsalt,
