Guest viewing is limited
hi im a newbie
3mm for me and a good flexi grout such as bal superflex
when will i need to seal the tiles after fitting before grouting, or before fitting the tiles. they are a light sand colour with a matt finish. it doesn't say on the box and i bought them from homebase and knew more than the staff i asked.
i here some porcelain tiles need sealed on the underside before fixing as it can draw the adhesive through and show slightly on the polished finish is this the same for a matt finish or is this ****e info!
I seal porcelain after fixed and grouted ( if needed ) I usally test an off cut with an inky and see how easy it wipes off.
Never heard of sealing the backs of them, would use white addy on them anyway if shaddowing is your concern.
sorry pal whats a inky
I'm with diving tiler on porcelain, 2-3mm, although I have done a 1mm joint previously at customers request. Did look good and no problems with it over 4 yrs ago.
hi im a newbie
Tags Tags
newbie usa
tricky15,
tricky15,
tricky15,
tricky15,
