How do you get your Grout lines to meet?
Well I would certainly set out from the lowest point of the room so that if you have to do raked cuts you will know what your biggest and smallest raked cuts are gonna be at the bottom and you do the same thing above the datum line... ie find the highest point in the ceiling and do the same. You can then play about with it, moving the grout lines up or down until you get the best outcome around your obsticles and good cuts at the top and bottom. So the lowest point in the room is as good a place as any to start tiling as long as the setting out is the best you can get it but I guess you could start anywhere. There are other ways of doing it but if you are new to it and not sure where to start it is a good point of reference. This is just an overview of how to set out using this method. I was taught to the British Standard of setting out but I realise there are quicker ways once you get used to what you are doing. If you want to know the full method paddyh2 pm me because it is a bit more detailed than I have said in this post.
Spot on sWe cheers for that
a customer vof mine has local authority people working at there house and are unhappy WITH THE SITUation so sorry
i run a batten around the room and tile around it so i know im at the same height. Then im able to continue this allthe way around so i know im going to meet.
Even if it finishes above a door way i know my battens are right and working below them is the same but upside down!
I butter the backs of around 20 tiles then throw them against the wall wiv my eyes shut! This keeps everything messed up just the way i like it!
Well thats what i may a s well bloody do!!!!
Thanks sibs,sWe
It makes good sense.
As a nervous novice I always tend to go as mid-tile as possible on the bottom row so any deviation doesn't catch me out, and making sure there's no small cuts anywhere else.
Thanks sibs,sWe
Have you read my "guide" to centering tiles? I'll post it here in case you'll find it usefull.
Stop reading if you haven't got a few minutes to spare.
I figure most of the people on these forums know the things I'm about to write, but I'm going ahead anyways, as there's sure to be people who don't.
There are a few things you need to consider when centering tiles on a surface.
First you need to measure it. Remove say 4mm from that number for 2mm margins on both sides of the surface, as tiles could come loose or crack from building movement otherwise. Then divide that number with the width of one tile plus the width of the grout. That give you the number of tiles you'll be able to slap onto that surface. Here's what to do next:
1. If the number of tiles is a whole number, say 11, just go ahead and use whole tiles all the way, unless the costumer wants something else. If the decimal numbers are very low, or very high, say 11.1 or 10.9, then you might be able to compensate by altering the width of the grouting, depending on the size of the surface, the size of the tiles, and the customers wishes. Pretty much self explanatory.
2.If the number of the last whole tile you can fit onto the surface is UNEVEN, for example 5.4, then you can go ahead and just mark out the centre on that surface, unless 1. is applicable. This is because the border tiles will always be half of a tile (which can only happen if the number of possible tiles is a whole number) or LARGER. The centre of the surface is found by dividing the width by 2.
3.If the number of the last whole tile you can fit onto the surface is EVEN, for example 4.7, then you need to approach it sligthly differently. I will get to how in a sec, but as to the why, it's because the border tiles will always be half of a tile (for the same reasons stated ), or SMALLER, if you work from the center of the wall.
Instead, you need to offset the centre of the wall, and work from the center of the middlemost tile. You can just adjust it so that it sits centralized on the centerline, but if you want use that line as a guide, you can do like this:
Divide the width of the surface by two, and then substract (or add) the width of half a tile. Mark the result on the surface, and work from there. You just made an offset central marking. It's offset by half a tile, and thus, the border tiles will be half a tile or larger.
If you want to check that your markings are correct, and that the border pieces really are as big as they can get, here's one way:
Add 1 to the decimals from the result of the calculation where you figured out the number of possible tiles.
For example, if the result was 6.7 tiles, then do 1+0.7. That gives 1.7. Multiply 1.7 with the width of one tile, and then divide that number by 2. The result is the largest possible width of two equal sized border tiles. Mark them out on the surface if you want additional guide lines.
I probably don't need to say it, but all of the above works vertically as well as horizontally.
I hope someone finds this usefull. Proper measuring and planning makes work sooo much easier.
:lol: :lol: never thoght of that one:lol:
hi m8 new member from northern ireland see u support rangers nice 1 i am going over 2 the game flying out 2day! r u going?:8:
Ian-garretridge
I like the batten method, but have lately been drawing my reference line around the perimeter for the first course, cutting those, mortar in place and then I have a nice level foundation to work up from.
infidel,
Paul,
infidel,
Paul,
