I
Italy
no?We don't get many of those in the UK Antonio
hai,hai
then, a problem to be added
Discuss How Hard Is This? in the Australia Tiling Forum area at TilersForums.com.
But, as has been mentioned, if you run a border you can use that to square it up a bit as long as it's not wildly out!We don't get many of those in the UK Antonio
Don't disagree Steve, everything u mention is more than possible.I'm not so sure that adding a border will speed things up much. Its through 4 rooms and setting that out so that even-ish size borders around each room may in itself take a while. Also with UK builders its quite possible that the walls will run so far out that it will show in the wedge shaped border! If the tiles cut well then a modern cutter that can be set to scribe/break at 45 degrees the job should be fairly straight forward; just allow the extra labour for 1) laying herringbone and 2) laying/cutting at 45 degrees. I would want, however, the edge of the tiles to be covered with skirting board after fixing because I suspect there will be a few edges of cut that run off on snapping.
courage mactenNo not got a floor laser. I think my biggest worry is if it strays off line or comes out of square even in the slightest then I'm going to be screwed later on. I know that's the same with regular floor tiling but you can spot it a mile off and it's easy to keep in check with straight edges. My OCD is helpful at times but it goes into overdrive if I'm stressing and it becomes a total mare and a hindrance. I think I've thought myself out of this job which is a shame because you've all given me great advice and part of me really wants to do it.
I've got one of these, had it many. A must for floor tiling....will pay for it's self on one job.No not got a floor laser. I think my biggest worry is if it strays off line or comes out of square even in the slightest then I'm going to be screwed later on. I know that's the same with regular floor tiling but you can spot it a mile off and it's easy to keep in check with straight edges. My OCD is helpful at times but it goes into overdrive if I'm stressing and it becomes a total mare and a hindrance. I think I've thought myself out of this job which is a shame because you've all given me great advice and part of me really wants to do it.
lots of things can go wrong when doing wood plank herring bone and if you've never done one before my advice would be walk away especially if you have a fussy customer you could get stung and out of pocket if the client doesn't like what you've done. cut your teeth on an easier project
If viewing a job, tricky or not, take pictures, get some measurements on them. This way you can always ask members on here for their input, bounce some ideas about.I often over think a job but once I actually start end up thinking "what was I worrying about"! If you can get someone to work with it can help because you have someone to bounce ideas off and they may see something you don't.
What a daft thing to say !!lots of things can go wrong when doing wood plank herring bone and if you've never done one before my advice would be walk away especially if you have a fussy customer you could get stung and out of pocket if the client doesn't like what you've done. cut your teeth on an easier project
what im saying is ive made a lot of money over the years correcting other peoples work.What a daft thing to say !!
How you ever going to get better if you don't push yourself. ..
Take your time even if you loose money the experience will be invaluable. .
Reply to How Hard Is This? in the Australia Tiling Forum area at TilersForums.com
