Thought I'd throw in how licensing works in AUS.
Licensing is currently run on a state level, with New South Wales and Queensland the only two states where licensing is required.
Under Queensland
regulations, anyone carrying out building work of any kind valued higher than $3000 must be licensed through a government run department, the Building Services Authority.
The $3000 value includes labour and materials, so for a tiler, it also includes the value of the tiles. All builders must be licensed and are required to only engage subcontractors who also hold a license.
All license classes allow you to do "Incidental work of another class". So you can do small scale plastering, carpentry work without having to bring another guy in, except for plumbing and electrical work.
When and if things go wrong, the consumer registers a complaint with the Authority who is required to take action. If the work done is unsatisfactory or faulty and does not comply with Australian Standards or manufacturer's recommendations, the Authority will issue a "Direction to Rectify" to the head contractor. By that I mean, if a builder is involved and he has engaged a tiler, the direction goes to the builder as he has the overall contract with the client. He than has to sort it out with the tiler.
The direction is enforceable and failure to rectify result in prosecution, fines and demerit points. This system has been in place in Queensland since the late 1990's and starting this year, national licensing is being brought in, although no-one knows how it's going to work yet.
Now then.......
Is licensed contracting being enforced? Not really. They try, but it's almost impossible to track unlicensed "tradesman" down.
Has it improved the quality of workmanship? No
Has it reduced the number of cowboys? No, in fact, most of the have been handed a license.
I don't want to but a downer on the whole licensing thing because I thinks it's needed, but if regulation is in place, it needs to be done better.
