Discuss How would you do it ? in the UK Tiling Forum area at TilersForums.com.
L
Leatherface
I am very curious as to the training methods on some of these courses & how they equip new tilers to deal with certain situations.
Take this job for example..
I am in the process of quoting a kitchen & dining room floor in an old house. Approx 20 sq metres. Limestone tiles over UFH. Tiles are 22 mm thick.
Only problem is that the room slopes downwards and to either side away from the kitchen and down towards the front door and main radiator bleed valve.
As it is good practice to lay a coat of self levelling compound over the UFH mat, it looks very likely that after laying the mat ,a coat or 2 of self leveller ( which will be deep in the lowest area ) and also the 22mm tiles and adhesive, the customer may have to have her door seriously altered & also her radiator.
My question is - how would any of you newly trained tilers tell the customer how much her floor will need to rise at the lowest point & also tell her where the lowest points are ?
wivers
I have never been trained to deal with this nor have i ever had to face this problem thankfully, so as a NooB i would probably try and find the highest point of the floor and then try running a level line around the room from that highest point so i could visually see how much the floor was out ....... whay do i feel like a school boy putting his hand up to answer a question and waiting for the other students to laugh at the answer?!!!
sparky
how about putting a level line all the way round the room then measure from floor up to the line if there is a difference then thats how much the floor will be running out
sparky
not bad for a 5 day tiler though eh :shades_smile:the quicker way would it involve a staff by any chance
CON5933
If the customer isn't havin the walls tiled she/he mightn't thank you for drawing on them...
For a good 'visual' display you can get the nearest level high point on the floor nearest to the radiator and put a tile or 2 (depending on depth)on the floor, stack a few tiles at the low point near the rad and then using a straight edge and level from 1 tile stack to the other would give a vivid and clear picture of the drop.
Failing that.... throw a laser level along the base of the wall..:)
L
Leatherface
That is the way I did it - she didn't want pencil marks all over her expensive wall paper - so laser level & staff.
Dan - it's obvious that by the time that the lowest point was levelled to meet highest, then heating mat, tiles ( 22 mm ) plus adhesive, they would have to take about 400mm off the door & alter the bottom frame & storm guard - The radiator & bleed valve at bottom end would be partially covered & all skirting boards would have to come off or disappear if left on. Also the stone fireplace hearth would disappear.
Reply to How would you do it ? in the UK Tiling Forum area at TilersForums.com
Got a kitchen floor to do and it consists of a concrete floor which then meets a timber floor...
Hi everyone, I’ve a fairly basic question I thinks, hope someone can help me out with. I’m...
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
