I bought a dewalt d24000. Why you sell yours!
have to look at mine tomorrow, but I think once the tray is on it should hit a stop when you pull it towards you, the wheel shouldn't come of the rail
When I have first 2 wheels on, it glides OK. Wouldn't be able to slide it up to cut point thou without 3rd wheel on. Once 3rd wheel on, and able to push up to cut point, this is when it needs pushed with slight force rather than glides. Defo something up!
Can you check yours to see when putting tray on, and when it comes to putting 3rd wheel on rail, does yours line up perfectly or like mine in the pic!
just looked at mine, as you say last wheel is of at start of run but mine glides straight on to the bar with no issues.
sounds like something out of alinement. If the first two run smoothly then maybe the last wheel is out.
where did it come from?
need to speak to supplies or Dewalt do a repair/maintenance survive
Bought brand new in place in north of Ireland. Was thinking same about wheel being out of alignment. Have a job starting on mon, looks like it's back to using my plasplug cutter 🙁 Very disappointed at this!
Not much help as mine looks a bit different (about 8 years old)
If I don't set mine perfectly level my tray will slide all the way forward or backwards under it's own weight and it should glide effortlessly.
I know it's hassle you could do without and you wanted it Monday but you need to send it back for a replacement.
They are a really handy cutter to own.
looking at your pic again it looks like that wheel is out of alinement to the left, maybe a simple fix to adjust it over
Bought mine from new. Sent it back as the side bed wasn't level with the main bed. Next one was better but still not dead flat. Also problem with the sliding action. Took it into my local dealt repair centre and the guy spent 8 hours rebuilding it.
Man what a great saw!!
