Discuss i like butt jointing tiles in the UK Tiling Forum area at TilersForums.com.
sus
Hello chaps
thinking of re tiling my kitchen using some B & Q 600X600 (porcelain) which I have left over from a job lot I bought for about £5 per meter, any way I want to butt up the tiles i.e. no spacers (I don’t know the correct term) I have seen this done many times but on a few jobs I have seen floors butt jointed with a few cracked tiles. Can you suggest why this has happened and how I should go about this on plywood base going straight on to 600x300 porcelain? I am not taking up the old tiles I have some costly devimat underneath that I do not want to kill (unless you can suggest something else). Thanks in anticipation
sus
david campbell
ok then!
firstly this really isn't a great idea,ideally you should strip back everything thats alredy down and start again,then the idea of "butt jointing" will only cause you problems later on as i previously said if your going to lay the tiles on ply there will always be movement therefore using a flexible adhesive and a flexible grout is the only way you can guarentee the tiling work will last for many tears to come
Grace'sDad
Butt jointing should never be done on timber or any floor which is likely to expand and contract. In the UK thanks to out beautiful climate, even asphalt and concrete floors are likely to move enough to upset butt jointed tiles (given the right combination of events).
Butt jointed tiles are seen mainly in warmer, more stable climates.
Not a very good idea in my opinion, even if it does look good (at first).
L
Leatherface
if you butt joint them the end product will be like crazy paving,,b and q specials are all different sizes:dizzy2:
I agree Kilty
No disrespect to guy who started this thread, but best place for B & Q tiles is in a skip, buried 200 miles underground in the Sahara Desert :hurray:
sus
some one has re tiltled my post i think. it should have read "i like butt" anyway now thinking about it the butt jointed tiles i have seen are mostly on concrete, one was defo in wood floor but that is one of the ones with cracks. Secondly the flooring had new joists at 300mm centers, plywood 10mm + 18mm, then devimat then flexi adhisive (bal i cant remember whitch one) then 300x600 and i was intending to put the 600x600 on top with flexi (mapai) but now i will use spacers. I dare not take the old tiles off in case i break the UFH. I didnt mean i have seen loads of butt jointed tiles on wood substrate i mean i have seen lots of butt jointed tiles. i have them in my bathroom and they have been there for about 120 years
Reply to i like butt jointing tiles in the UK Tiling Forum area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
