Important Changes to Tiling Standards
British standards aren't regulations but guidelines. It is in those guidelines to waterproof wet areas though and I'd wager they haven't. Throw that back at them. The threat of posting all over social media usually works with big firms too. Good luck
Thanks, I was tempted to post on social media but was worried it may harm my case 🙂
Unfortunately setting out issue...Not really much can be done other than add a small cove detail
Or remove top course and slither/ introduce a listello border then larger cut... or .... rip out and start again
The darker grout does emphasise it
Have definitely seen worse
As @hmtiling
Said ask them if they have waterproofed the walls before tiling as that is in British standards also as @Boggs
Said I have tiled an awful lot of bathrooms where I haven't tiled a whole tile of the bath , and yes do not get confused as to what british standards are they are a code of good practice and not even building regs .
And yes they should of siliconed the corner where the tiles meet also have they siliconed next to the bath
They have white siliconed the tile/ bath join however it seems to be peeling away a little. There is translucent Silicon in the corners however one side seems to be yellowing?
It's no good siliconing over grout in the corners, this joint is meant to be free of grout and adhesive, this is a movement joint , British standards therefore they should know this (hint of sarcasm ) . I would of done that in a colour match Silicon but that would be more expensive that generic cheapo Silicon .
Cheers this for the info this is a great help!
Tiling Standards
Matty A,
Dan,
Matty A,
Dan,
