Guest viewing is limited
Discuss Is my tiler using the correct adhesive ? in the UK Tiling Forum area at TilersForums.com.
graybags
My wife decided that my tiling wasn't up to scratch in the ensuite and therefore got a pro in for the main bathroom.................but I'm not sure that he is !
The tiles are Instal Bianco porcelain 450x250 and for a start he appears to have primed the walls (a mix of aqua-panel, plasterboard and plaster) with PVA and is using a ready mixed BAL adhesive (BAL grip) which I think is acylic based , when I thought that you should use a cement based powder adhesive to mix yourself for porcelain tiles.
Please tellme that I am worrying unnecessarily !
penno
Quite simple mate, the gear being used is NOT right for the job. Get the number for BAL tech line if he disputes it and they will put him right.
Maybe ask him to start again and you would like the correct gear to be used, he replaces the tiles already used at his cost?
Try and reach a compromise without too many fall outs but do not let him continue with the grip gear no matter what he says.
graybags
Call me old fashioned, but I'd prefer not to just accuse him of doing it wrongly, but simply ask why he is using certain adhesives, preparations etc, when "isn't X,Y,Z what is more usual"
I think I am right in thinking that cement based adhesive is the best choice because it goes off by chemical reaction, not evaporation, the latter being impeded by large format, non porous tiles where moisture will take an age to disappear, but what is the story about PVA ?
L
Leatherface
Just to point out there are a couple of tubbed ready mixed adhesives that are suitable for porcelain tiles, though large format porcelain do not fall into that bracket
Granfix Multifix is one of them ...
http://www.tileadhesive.co.uk/PDF files/Multifix Adhesive.pdf
Also this adhesive is self priming, so no need for pva or any other primer
grumpygrouter
PVA will become "live" again in contact with moisture. Dispersion adhesive contains alot of moisture so the pva will not do vey much apart from become slippy. There is a very good thread on here about primer v pva which I am sure Dave has a link for and will post it up for you.
Reply to Is my tiler using the correct adhesive ? in the UK Tiling Forum area at TilersForums.com
Hi All. Ive done some research which has confused me more than when I started reading. So...
Hi all, Just after a bit of advice please. I had my kitchen floor tiled last week (porcelain...
6K
Hello all, I could do with some advise if anyone would kindly help me. first of all, I’m not a...
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
