Discuss Is my tiler using the correct adhesive ? in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
cornish_crofter
cornish_crofter
Graybags, how you approach him is down to you. You know what approach is best for the situation.
My only concern here is that if he doesn't know these basics, then what is your bathroom going to look like when he's finished?
My Brother in Law had his kitchen tiled by a complete chancer. I've never seen such a bad tiling job in all my life! The real shame is that he had spent a small fortune on these tiles.
The problem here is that I suspect this job is out of this guy's depth. This may make you feel awquard but either you want to come out of this with a job well done, or you want to avoid upsetting this guy, you may not be able to achieve both.
If it were me, I would probably pay him for the time he's spent at your job and ask him to stop and pack up. You can make an excuse to the effect that your wife hates the tiles and apologise for causing him an inconvenience.
There are plenty of good tilers on this forum who are short of work. You don't say where you are but if you PM Dave or ask in the Tilers Wanted section you will no doubt get a few replies.
It's a tough call but at the end of the day I assume you and your wife want a good job done.
graybags
In fairness to him he may not have primed all the walls, just that there is a tub of PVA on the window sill, which I guess he might have used on the one plastered (outside) wall. The other walls are all studwork and hence are plasterboard/aquapanel. Would you normally prime them, or just tile straight on them (with the correct adhesive !)?
grumpygrouter
For using a cement based adhesive it would be normal to prime plasterboard but if he was using "grip" then it is not necessary. Aquapanel doesn't need priming at all.
graham31
The actual quality of tiling, cutting, grout lines and levelness is excellent, just wondering whether if he hasn't used PVA on the non plaster walls (which it dosen't look like he has) whether the BAL Grip adhesive might just hold the tiles.They are 450X250, not 450x450, so not "huge"
Still large format are they not?To big for tub addy
Reply to Is my tiler using the correct adhesive ? in the British & UK Tiling Forum area at TilersForums.com
Hi All. Ive done some research which has confused me more than when I started reading. So...
Hi all, Just after a bit of advice please. I had my kitchen floor tiled last week (porcelain...
6K
Hello all, I could do with some advise if anyone would kindly help me. first of all, I’m not a...
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
