Discuss Is my tiler using the correct adhesive ? in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Bonding coat should not be tiled to...it isn't stable enough to hold tiles....and the picture frame effect is true...as far as the air can get it will dry and thats it.......some moisture will soak into the substrate but thats it...Also when pva is used it forms a skin and dose not impregnate the substrate like primers do....so when you apply a dispersion adhesive etc it wets the pva ,,thus making it live again and nothing really holding the tiles in place....so if the pva formed a skin on the substrates surface then thats all the tiles are held with..
Primers seal the substrate from sucking moisture from dispersion adhesives to quickly and with a portland cement adhesive it stops ettringnite reaction....
Those tiles might well hold...we are just trying to tell you the correct way it should have been done....as confirmed by the tech guy you phoned......
grumpygrouter
If you read the thread you will realise that we have been there and done that. The PVA was binned long ago, along with the ready-mix. This guys tiling is spot on and I would have no hesitation in using him again.
GLad you got all this sorted Graybags and that you have a job you are delighted with, and also that your tiler has also leaned something. You can be sure as shooting he won't pva again and I am sure he would be happy to do work for you again if you were to ask him.:thumbsup:
Reply to Is my tiler using the correct adhesive ? in the British & UK Tiling Forum area at TilersForums.com
Hi All. Ive done some research which has confused me more than when I started reading. So...
Hi all, Just after a bit of advice please. I had my kitchen floor tiled last week (porcelain...
6K
Hello all, I could do with some advise if anyone would kindly help me. first of all, I’m not a...
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
