Ronski
I've got an en-suite that we are building, it will quite likely be tiled with Limestone, although we have not made a final decision.
At the moment the room is a bare shell, 2 walls are stud partition walls, my question is what would be the best covering for these walls in relation to tiling onto it?
Wall 1. 3.1m long x 2.3m high
The studs are 90 x 38mm, at about 400mm centres, the other side of the wall has 12mm ply with 12.5mm plasterboard, so the walls pretty sturdy.
Wall 2. 1.45m long x 2.3m high
The studs are 38 x 63mm, at about 400mm centres, the other side is 12.5mm plaster board. This wall will have a shower cubicle on.
I had intended on using 12mm or perhaps 19mm plywood.
What's your recommendations please?
I will be doing all the work/tiling myself.
