Discuss Is this acceptable lippage? in the Canada Tile Advice area at TilersForums.com.
Hi all,
Recently had my kitchen tiled in a chess board style white & black 30cm x 30cm quartz tiles. The floor covers approximately 14m2. The tiler came highly recommended & has done jobs for friends & neighbours, I’m not so happy with the job he has done in my house. The job took 6hours from start to finish, he originally said 2 days but as it was a hot day he grouted too.
Communications have pretty much broken down, he offered us our £ back then didn’t show with it. Txt him a few days later & said there will be no £. Looking like the small claims court ahead. Pictures showing lippage & a map of the floor with lippage in mm. Can even put a 10p under a ruler with room to spare.
Any comments greatly appreciated 👍🏼
  • IMG_9711.MOV
    61.5 MB
Dumbo
British standard tolerance for tiles with a 3mm joint is 1mm , if I'm wrong someone will correct me hopefully as it may even be stated tiles with a joint under 5mm it is 1mm lippage , basically I'm not sure of the wording but it's 1mm . But understand british standard isn't law it's a code of good practice .
Thanks, too many are over 1mm
Tony_C
528
Glasgow
Time line seems a bit off to be complete and able for foot traffic in 6 hours. Perhaps a reason for some sunken tiles if they have been walked on too soon.
All tiles down in 2 hours then another couple hours to allow the first hour of tiling to be dry and then to grout. Time seems a bit tight there
Exactly what I thought
quartz tiles need a different adhesive (2 part from what I can remember from last year and expensive ! )
wouldn't even try and lay these in 1 day - should've used wedge fitting kit - take a bit of time and come back next day and grout - was the floor flat /level before tiling started ?
Floor was solid concrete, house is 6 years old there was no prep work done beforehand as he didn’t recommend it. I felt the floor was in decent condition, had Lino down previously. Was a hot day so said adhesive would dry quicker hence job done in 6hours. Should add 2 men, One cutting one laying.
Very poor job. I think he's rushed it to get it done in a day. The adhesive going off quickly in the heat is no excuse - he could've mixed smaller batches or used a different adhesive. Tilemaster do a semi-rapid adhesive which isn't bad.
If the tiles are agglomerated quartz he should have used a two-part adhesive - latex instead of water.
Either way it's not good enough.
Reply to Is this acceptable lippage? in the Canada Tile Advice area at TilersForums.com
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
I was quoted over £4700 (inclusive of VAT) to rip out and replace my bathroom. This does not...
7K
Hi All I'm looking for some advice from the experts and hope you can help. I've just had a...
It’s in open forum so ‘mind your language ‘! On Monday last week I did something I’ve not done...
WetSaw
Kilsyth
What member type are you?
  1. Homeowner
Business Name
Gobbledygook
    Votes: 9 6.1%
    Votes: 14 9.5%
    Votes: 11 7.4%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 18 12.2%
    Votes: 15 10.1%
    Votes: 7 4.7%
