Tiling Tool Suppliers
Blunt Tool
The wattage describes the power of a tool, so a 110v 500 watt drill is just as powerful as a 220v one.
What you do have to watch is the current. In a nutshell the 110v tool will take twice as much current as the equivalent 220v one. The more current the greater the voltage drop in the cable, so you should use shorter/thicker cables. Not using the correct cable will reduce the voltage at the tool, making it appear less powerful.
110v is safer. The live of a 220v supply is 220v volts with respect to earth, so if you touch a live and say a water pipe at the same time you will be zapped with the full 220v.
The 110v is in fact 2 55v supplies connected together to give 110v. The common connection is connected to ground, so if you touch one of the conductors and ground you'll only get 55v across your body.
I
Italy
phone call of the day,
former owner of battipav 160 says:
hey antonio, do you accept an exchange?
about what? give me back the BATTIPAV 160,
and I give you my new sigma 128 ........ :(
I replied: no thanks.
come on!!!!
give me € 100 difference and that's enough !!!
not even for 50 €, I do not exchange.
Hello.
Perry
These didn't look like a bad buy at Costco today.
Time's Ran Out
12K
Flintstone
F
H
5K
Diamond Pool Finishers
Tiling Tool Popular Threads
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
