Discuss just been over the shop... in the Canada Tile Advice area at TilersForums.com.
Does this watery grout hold up in vertical joints then? Thought it would just slide down lol.
AHA now that's another trick
The way we did it is mix a 3 and 1 sand and cement semmy dry mix. Then take some of the semmy dry mix and make a wet slurry. Apply the slurry to the tile joint using a broom or a float until all the joints are (flooded we always caled it the semmy dry method but what is in a name) then sprinkle the rest of the semmy dry mix over the joints leave to firm up in the joint and then buff up with a rag leaving the joint full flat and even. If the tile is porous you may need to buff over with a mix of sawdust and linseed oil.
Reply to just been over the shop... in the Canada Tile Advice area at TilersForums.com
