Haha, moving isn't really an option. all the surrounding houses have gas so im contacting the national grid to get quotes for a gas feed. The block next to us has gas.
So with it mot feeling anywarmer with heating on i decided to shut it all off and it doesn't feel any colder, so a day i was using 65kw with the heating on and i checked today over a 10hr period with over on and washing machine twice and we have only used 10KWHS , thats quite a difference something like £12 before and £2.50 now,
In the short fall i will bring home my 2.5kw industrial fan heater from work and having it on for 2 hrs a day will be 5kwh making my usage around 15 which will be significantly less than used underfloor heating. Cant understand why a developer would use underfloor heating mat as its only source of heat.
Im confident this flat will be toasty with my heater fired up for even half hour, it warms my workshop a treat. Needless to say im not a fan of this electric underfloor heating im sure on tiles as a luxury it would be great but really is expensive to run.
Just from having a read through the thread I noticed you mentioned you've got chipboard down but the heating is installed within concrete? If this is the case then this is where the heat is being trapped which is why your rooms aren't feeling warm. Electric UFH shouldn't have anything placed over the top of it other than the floor finish and that needs to be kept below 2.8TOG. If that's a 18mm chipboard over the concrete then that would taking all the heat.
That's a very good point, never really thought about it as i said im new to this heating and didn't take much notice , the only reason iknow it has chipboard on top is because the previous owner layed stick on looking laminate flooring throughout and its lifting in areas.
