Discuss Just read this and have an opinion please in the Australia Tiling Forum area at TilersForums.com.
charlie1
Really ..??? Sounds a bit extreme. .
yes, drop new ceiling and install spot lights on 90% of jobs. Re board all walls so they are plumb and if I get opportunity to go full tile on each wall then I take it, it all saves time rather than centring. Most 2m bathrooms, your never far enough away from any wall to know if it's not dead centre.
Mr Tiler
Hi guys,
Ok so I have come to a forum to discuss this. Last 3 jobs I have done on full bathroom installations working with a plumber. We have had the odd argument as I am or consider myself to be a good tiler....
All tiles have come from B&Q supplied by customer. The last job, the grout line went out slightly so the ceiling have a a row that went into ceiling uneven. Not too bad but hey ho... Anyway, I looke at the second tile in on that wall and its bigger than than the first tile. That's what has knocked the line out. I followed that tile. Ive been having battles with them. They are differ in sizes. Its making my job 10 times harder. Is it me or what? Is this a known factor?
Last 3 jobs with B&Q tiles they all change in size and on this job im using 4m grout line to make it look better (hide it) which I don't like doing.
Advice?
this is just lack of experience mate, ive struggled with tiles of different sizes too but you have to adjust as you go... its hard to explain but i suppose its like saying, one day after lots of practise you start to tile in a different way and your eye is on the ball all the time rather than relying simply on the spacers and at the end of the job notice things you should of a lot earlier!
AliGage
Subscribed
4,531
1,188
Peterborough, England
I'm not going to bother reading 9 pages after seeing your first response to TJ.
DIY stock tiles are generally tosh. If the tile your placing is significantly bigger to the one adjacent to it put it down a select another one.
You say you spaced it out to 4mm to compensate. Did you start with 4mm?
Round edge ceramic tile? Grout joints must look about 6/7mm? How do you fail to line up a joint that size, christ knows!
Reply to Just read this and have an opinion please in the Australia Tiling Forum area at TilersForums.com
  • Sticky
  • Poll
Which Tile Adhesive and grout brand did you use the most in the last 12 months? And also...
8K
My tiler has made a huge mistake (which he excuses as being unlucky with measurements). There is...
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Hi there I ordered 160sqm of 90cm x 90cms of matching Large Format Porcelain tiles. 105sqm for...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
