White Room
Are the walls stud work or block work....
mostly studAre the walls stud work or block work....
yesLooks ok to me whooshman,you should be fine with that!
is the 18mm ply straight onto the joists?
You need expansion!! Don't leave that out...yes
SO....going with what I have so far, no expansion needed, as long as some sort of uncoupling/backer used. Fair shout? If so, any you guys used the BAL Rapid mat?
