Discuss large format tile gaps in the Canada Tile Advice area at TilersForums.com.
Waluigi
The main thing to do is get the walls level.
Tell yourself that a perfectly plumb wall is the shortest possible distance from the bottom of the wall to the top.
If your adjacent wall isn’t Plumb then that same point from the bottom of the wall to the top of your wall will be longer so the spacing between tiles has to increase.
Hi All,
perhaps i did not explain myself properly so apologies,
the floor is 75 Sq meters, 40 Sq meters of this is is a perfect rectangle for a new built extension, the rest is through a hall way and kitchen / Diner.
The tile sizes again are 100 cm x 50 cm and to clarify what tile gaps would you be looking at ?
Albert
1,253
Gateshead NE8, UK
Hi All,
If the tiles are rectified i would use 3mm if not then i would
use 4mm
Reply to large format tile gaps in the Canada Tile Advice area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
Stoke-on-trent, Staffordshire
Business Name
G Freeman tiling services
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
