Discuss large format tile gaps in the Canada Tile Advice area at TilersForums.com.
area tiling
523
n.ireland
My last floor size was a similar rectangle , laid 120x60 rectified porcelain onto Kerakoll idro build Mat , followed expansion gaps on liquid screed floor , with ufh and put a soft joint in the middle of floor with matching Silicon used 2mm spacers ! Can’t see anyone wanting a 4 mm joint with an expensive tile, but that’s just my opinion!
Cranbrook
Ditto
Hope not to offend by sabotaging thread but I'm just about to tile a wall with 120x60 porc. and was going to use 2mm or 1.5mm gap. Is there any reason I shouldn't? the wall is only 1.8m long two tiles high. (shower cubicle)
If your wall is stable and load bearing and has no deflection, 2mm will be ok.
Reply to large format tile gaps in the Canada Tile Advice area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
Hi, I’d appreciate some help with lay out for four walls with following measurements. I want to...
Stoke-on-trent, Staffordshire
Business Name
G Freeman tiling services
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
