Discuss Lash clips etc Again ! in the UK Tiling Forum area at TilersForums.com.
it would just be the initial cost Dave that might put off a diyerWould you recommend these for a DIY'er such as myself?
what size grout lines are usually used for bathroom floor tiles (and wall) ?
that really depends on the size of the tiles, size of the room and customer choice, i usually use 2/3mm on the walls and 4/5mm on floors but some floors can have up to 20mm joints, but personally i don't like big joints.Would you recommend these for a DIY'er such as myself?
Morning Mike
The bathroom is about 7.5m2 i'd say
I was going to use 2mm on walls. To be honest I was going to use the same on the floor, but I have been thinking that 2mm will be a bit small. Then I thought that grout width should match the walls and floor if using similar tiles (as I am) wall tiles are oblong, floors are square.. same colour pattern, just non slip for the floor.
ie would 2mm grout lines on walls and say 4mm on floor look a bit odd?
Morning Mike
Cheers Neale, I just think it could be misleading to some folks, as you say, if your sub-floor is not flat then no amount of lash clips etc will help. 600mmx600mm rectified edge porcelain will not bend.
yeah but didnt you know that if you use flexible adhesive it will make the tiles bend ??? .....Joke !
Reply to Lash clips etc Again ! in the UK Tiling Forum area at TilersForums.com
