Level Access Waste
Bodman
Hi Everyone, I am currently fitting a wetroom but I have ran into a bit of a problem. There is a clay drainage pipe (no Idea what its off as there is nothing that could use it on that side of the house) running under the corner of the wetroom base and I had planned to break into that for the waste. So I have cut a hole and poured 2 buckets of water down it but nothing comes out into the drains outside 🙁
So Plan 'B' is to run a waste pipe (40mm) around the bathroom and break into the soil stack, As the run would be about 5.5Meters what would me options be. Im aware I need about 60mm of drop per 3M pipe, but I have also seen level access pumps but not sure which one and they seem expensive.
Bathroom.jpgp
Any help greatly appreciated.
//Bod
I have pumped wastes but as you say they are expensive, Email me and get me the details I will work it out for you maybe you dont have to go to that expense
tiler
Level Access Waste
Tags Tags
level usa
Bodman,
wetdec,
Bodman,
wetdec,
