Hello folks,
I'm wondering if anyone can point me in the right direction with levelling a wall that I'm about to tile.
I've completed the first wall which was fine, nice and level for the most part (or nothing that building up a small bit of adhesive wouldn't solve). However when I placed my wooden batten across my second wall I noticed that it bows into the middle.
It appears that most of the problem is from the very sides (left and right) of the wall where it slopes up quite sharply, while the middle might be a bit more flat with the odd lump or bump.
Here is the wall:
With the batten placed across the entire wall it is raised off of the wall:
With my spirit level placed in the middle of the wall the gap is much reduced so I think the sides are causing the batten to raise (1cm would be an extreme max for the gap, I think it's around 0.5):
A single tile produces hardly any gap:
So I'm not sure how I should go about solving this? Is it actually an issue, i.e. should I just be raising and lowering the tiles with adhesive so they match up but still have the wall overall bowed?
Or should I attempt to plaster the wall to level it off (my plan was to flatten the plaster up using my batten to make it level, it's behind tiles so I imagine it doesn't have to be too neat). Could someone help me with the method for doing this? (I'm plastering ONTO finishing plaster (urg) so how would I key it, what plaster should I use to build up the 2cm gap in the middle etc). I don't think I could use plasterboard because it would make the tiles jut out from the wall quite alot. Obviously I'm mostly concerned about the weight of the tiles pulling the new layer of plaster off of the wall.
Much appreciated for any advice, thanks will be added (and possibly pics of progress ).
Here is the wall:
