Discuss Levelling a wall - any help please! [pics] in the UK Tiling Forum area at TilersForums.com.
Use rapid set and mix it quite thick, if you're anything like me I get impatient and try to put too much on and it can slump.
Try to source the cheapest rapid set (usually grey) when skimming walls or it could cost you a small fortune. BAL is good but BAL is dear.
You can use grey but you will have to work very clean, particularly with the grout joints.
Yeah it was the grout joints that I'm worried about. With the white unibond stuff I'm using any of it that is coming out I'm not so bothered because I know the grout is going to be white so it'll definitely just merge in.
I may buy a small bag of grey to skim and a big bag of white to finish the rest of the walls in that case.
Well kerraquick maxi is one I will definatelly pay more attention to because that would be cool.But I am certain the more the gap of adhesive behind the tiles the more they move by themselves as they dry with most other adhesives anyway.And i doubt this guy is using kerraquick maxi!.I would be interested in some other opinions on adhesive shrinkage?.,
Dont use timber as a guide, use a straight edge or level!!!
i must admit i am surprised that as your dip is 10mm or less no one has suggested that you use a floor trowel (20x10mm round notch) and serrate the wall and the tile,
if you do this once your first course is on the wall you can use a long level and push the tiles flat!
therefore no need to "plaster" the wall with adhesive!
both ways will work but, as your dip is 10mm and less, i would use a good quality flexi and follow my tip!
Reply to Levelling a wall - any help please! [pics] in the UK Tiling Forum area at TilersForums.com
