Discuss Levelling clips are a load of tosh? Really? in the Canada Tile Advice area at TilersForums.com.
If you’re using clips for the first time, buying Cheap is a mistake!
Buy a reputable brand, they tend to be easier to use because they’re well established.
If you find you’d like to use them in the future, then you can move to something that you may feel is more cost effective.
Like anything, you need to know what they should be like to use first.
Otherwise you won’t have anything to measure them by.
Chris N
268
Nuneaton
I asked the question earlisr, any chance of an eBay link? Cheers, Chris
There are dozens of systems out there, my advice would be to choose
Genesis or Rubi from Sam @Pro Tiler Tools
(Not the new quick system)
Tile Leveling Systems | Pro Tiler Tools - http://www.protilertools.co.uk/tiler-tool/3191/tile-leveling-systems
The most common style are...
Raimondi from
Colin at Kwik Split or
Jim Stott at Tiler tools
PLM (perfect level master) from Nick Ward.
Mustang from Andy Carroll.
Then you can make an informed decision.
Yes they’re available on ebay, but a large percentage are rip offs from China.
Whilst some are more than useable, a lot are not.
Without a yardstick to measure them by, you’ll still be in the dark.
Spare Tool
Raimondi from
Couldn't agree more, I worked my way through quite a few (duff ones at that) before I found one I was happy with..
I've never used spacers when tiling floors, just a straight edge.......... This is the only thing that puts me off using them.... I would have to change the entire way I tile.
Not with the right choice Andy, in your case I’d suggest the genesis or Rubi type.
That way you can tile in your normal manner and tighten any clips down from above.
Even on large floor areas Andy? I used to not use spacers on bathroom size floors, but always on bigger areas. The clips are usually only 1mm thick so you will still need your expert eye
Don’t really hold with that idea Andy, if you’re using wedge type, as you tighten them they will move the tile as you push the wedge in, even with the correct pliers. The wedge will grip the tile and move it.
Reply to Levelling clips are a load of tosh? Really? in the Canada Tile Advice area at TilersForums.com
We just had a 1.5 sq. m area of floor tiled professionally in our ensuite. The base floor is 18...
Hello, looking for advice and what to do next. Have had main bathroom installed via a local...
I was quoted over £4700 (inclusive of VAT) to rip out and replace my bathroom. This does not...
7K
I'm a chippy, I fit a lot of kitchens and some bathrooms, inevitably I have done quite a bit of...
20K
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
