lifting tiles - Why?
Morning,
Can someone tell by looking at these images why the tiles have loosened. Laid on floorboards with 12mm Hardie screwed down on a bed of cement based adhesive. I'm confident floor itself is sound. Tiles are 300 x 500mm ceramic wall/floor and laid using slow set adhesive. It seemed to take ages for adhesive to go off - well over 24 hrs. Remaining tiles seem ok no hollow sound. But I think they would be easy to lift.
Adhesive mixed incorrectly, not enough water, no back buttering, adhesive not flexible enough, to much bounce on the floor due to incorrect prep...
Fact is tiling onto a wooden substrate is a minefield, unless you get everything spot on chances are it will fail.
Unless you give us the full information we can't say for sure what your issues are but I suspect there could be more that one. !
No back-skimming to fill those waffles either.
Possible dusty backsides on the tiles?
I'd guess - too stiff a mix, possibly skinned over before no real effort to achieve a solid bed. Those tiles should be back skimmed and given a twist/push/pull.
trevean,
Andy Allen,
trevean,
Andy Allen,
