DHTiling
Elasticising admixture to be mixed with Keraquick for increased flexibility, and with Nivorapid for not only increased deformability but also improved adhesion on difficult surfaces.
Applications:
When mixed with Keraquick, Latex Plus forms an ultra-fast setting adhesive with high deformability for interior and exterior installations of ceramic tile, stone, insulation panels, gypsumboard, etc. When mixed with Nivorapid, Latex Plus forms a super-rapid cement-based levelling compound with deformability and adhesion for use on highly deformable surfaces in interiors (wood, metal, PVC, rubber, etc.). Latex Plus must substituted for the total amount of mixing water normally used. Coverage
with Nivorapid: 0.6 kg/m2 per mm of thickness;
with Keraquick: varies according to the amount of Keraquick and the mixing ratio. Packaging
10-kg drums.
Ultra-fast drying (4-6 hours) thixotropic cement-based levelling mortar for vertical surfaces for thicknesses from 1 to 20 mm.
Where to use:
Interior levelling on any kind of substrate normally used in building as long as it is clean and not subject to moisture such as:
• concrete slabs and walls, masonry, renders and cement based screeds, etc.;
• also suitable for old floors and ceramic tile, natural stone and terrazzo wall coverings;
• suitable for repairing or levelling steps, edges of columns, depressions and holes in floors, walls and soffits.
Particularly recommended where the substrate must be covered within a short time.
Apply from 1 to 20 mm per coat.
Consumption
1.6 kg/m2 per mm of thickness.
Packaging
25 kg bags
