H
hillhead
Oh really? Ever been to the finer parts of Brixton? :smilewinkgrin:
No minnie,lol.
us tilers do have to keep joints clean as we go! get a good stanley blade and scrape out the high bits of adhesive
Discuss Mapei Grout in the UK Tiling Forum area at TilersForums.com.
LMAO.
It doesn't matter whether you use BAL, Mapei or any other manufacturer, if you don't clean the joints, the grout will look ropey.
No minnie,lol.
i had to remove mosaics once last year(customer hadn't enough of right colour,and couldn't get more).
wow,pain in rear there,i had stuck them on with a top quality bagged adhesive!!
took a lot of work to remove.
I don't want to end up with grey grout and there's no way I'm going to be able to get all the adhesive out from between the mosaics so maybe I'm better off going for the BAL.
The adhesive is erm, I dunno, sort of like Polyfilla colour :lol:
If you asked me to describe Polyfilla colour I'd be stuck. It's not pink, it's not grey, it's er....
in answer to your original question minnie
yes you need to use the correct amount of water as specified
using too much water can effect the colour of the grout
it can cause white grout to dry out with a slight greyish tint
The grout rakes are ok...but if the blade is wider than the mosaic joints, then it will not work....check the width and if ok then use a rake..
Well the Stanley is too thin, and slightly dangerous to work with at funny angles, especially considering how clumsy I am :lol:
I already got a tile splinter in one finger and accidentally nipped myself with the tile nippers (first time I ever decided not to wear gloves and I nip myself instead of the tile :lol
Reply to Mapei Grout in the UK Tiling Forum area at TilersForums.com
