Marmox Boards on the Floor andUFH
Hi Everyone
After a couple of weeks worth of building, etc distraction I'll finally be starting the bathroom this week!
Thanks for all your help and advice so far!
I thought of buying the 2500mm 10mm & 12.5mm Marmox boards as room is approx 2500mm tall and floor is approx 2800x2400. Are the 2500mm boards hard to use? Would u recommend using the 1250mm ones instead?
Also, do I need to leave any expansion joints where the wall boards meet the floor/ceiling and where the floor boards meet the walls?
Finally floor is out of level by approx 10mm across the 2400mm width of the room. Is it ok/possible to level this by using more tile adhesive under the marmox board? They are going over 25mm WBP Ply (thought of using Keraquick without added latex).
Thank u all so much again!!! 🙂
Sent from my iPhone
Use the 1250 boards, yes do incorporate expansion joints and use SLC to level after laying the UFH.
Hi Everyone
ive finally dot and dabbed the boards. It was a lot easier and less intimidating than I thought it would be...thank god!
I now need to drill through and screw with metal washers (instead of the plastic hammer in dowels). I think it's a dumb question but do I use normal red or brown rawl plugs which won't go much deeper than the keraquick dabs or should I use other fixings that go deep into the brick walls behind?
thanks again for your help!
Normal rawl type plugs just fine. Drill through further to allow for the depth as you say. The rawl plugs should be into the wall though for a solid fixing. Did you pre drill the board prior to spot fixing?
Thanks PTT
I punched 5 holes with a screw driver and put large dots over them. I also put dabs all over the edges and many more in the middle. Tbh it looked like overkill but the boards are 12 mm and I was worried about them flexing if there wasn't enough adhesive (did seem to use a lot of Keraquick though (and its pricey). :thumbsdown:
Ok...so shall I drill a bigger hole (eg 8mm) in the marmox/dot/dab and then a 6mm hole (for the rawl plug) in the brick? I've bought 50mm long stainless turbo ultras so hopefully they'll be long enough to reach.
For the bath panel, can I build a frame out of 2x1 and fix 12 mm boards to this? Should/can the bath sit on the frame? If not, how should I secure it? The reason for 2x1 is so that the tiled finish is flush with the edge of the bath. I have to make a tiled panel for the top end and one side of the bath with access for the taps/trap.
thanks again!
No, just use a 6mm bit to drill through both but you just need to ensure the rawl plug is in the wall securely.
As for the frame, I would try to use cls if it will allow. Fix frame securely to walls and floor (can even use a mastic type adhesive across the top where it adjoins the bath.) Make sure it is a solid rigid frame for the marmox to fix to. You can use thinner marmox here if you like. Two vertical uprights within the frame should suffice. I often use keku or magnetic fixings for hidden panels with a neat bead of Silicon instead of grout.
Thanks again PTT 🙂
For the CLS frame, what sized timber is the minimum I can safely get away with? The edge of the bath isn't very wide and I think the tiles (marble) will be about 15mm so I'm not sure ill be able to use 3x2.
for the hidden panels, do u fix the keku/magnets to the back of the marmox board? If so, can't the screw rip off the marmox when pulling the panel out?
Thanks! 🙂
Basically you need to use the biggest size you can get away with under there. I use 3x2 if I can. I screw through from the face of the marmox using a washer to spread the load but use screws that screw into the plastic holes of the keku fixings. Once tiled over on the front it is a very solid fixing!
You have a floor area approximately 2.4x3m = 7.2m2 based on a 100w/m2 mat you will get a heat output of just 720w per hour. That dies not allow for any downward heat loss. You need to calculate the rooms heat loss to see if 720w/h will overcome the heat loss. If the heat loss is more than 720 your room will never warm up ad your electricity bill will be huge.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
