Discuss Marmox in Northern Ireland. in the UK Tiling Forum area at TilersForums.com.
Dan
Admin
Staff member
5,088
1,323
Staffordshire, UK
Underfloor Heating | Electric | Warm Water | Floor Insulation | Frost Protection | Uheat sell it you could ask them for a bit of a small stock for yourself, and then mention it to a few other tilers, and perhaps even make back your delivery costs by selling it for a slight profit to cover it perhaps?
If you can buy a fair pallet load and shift it regularly, Marmox will even give you an account for you to buy direct, I'm sure. Worth considering if it's so rare, maybe?
Not sure what the score is with transit from the UK to NI to be honest, whether ship or air is used or what. So not sure what would work out cheapest but worth considering because the amount of jobs it can be used on is quite high and people tend to cut corners when they're not using such products.
I think Wedi is quite heavy so you'd have to factor that in when considering shipping with that stuff. But Marmox is like transporting air in a box around. It's just a big box.
Ascot
Thanks for the suggestions. Unfortunately I'm just DIYing and don't mix with too many other tilers but good tip on the weight difference between Wedi and Marmox! Have you used marmox yourself? Its the light weight and the easy cutting that appeals to me.
Thanks to the posters on this forum i have been convinced that sheeting out my stud wall at my shower and the box behind my basin and wc was a bad idea for tiling onto, so i'm switching to a good backerboard.
ruairi mac
Hi Ascot, do a quick google search for Multi Pro Board, they're based in Belfast. They manufacture tile backer boards I recently used there 6mm stuff to sheet over a bathroom floor. First time I used it and found it pretty good.
If you ring them they should be able to tell you your nearest stockist.
There website has full data/technical sheets to refer to for installation/usage purposes.
If your unsure bout anything just give the tech dept a phone and they should help you out no problem.
Best of luck
Ruairimac.
Reply to Marmox in Northern Ireland. in the UK Tiling Forum area at TilersForums.com
Hi guys, had some great advice here before so thought I would ask here for advice again...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
