Discuss Matting question in the Canada Tile Advice area at TilersForums.com.
Wesley
273
East Anglia
All, I am about to start a job and plan on using Ditra 25 over concrete. Talking to my local, very good supplier, he has suggested I try a new Ardex product under the Ditra matting. I didn’t get the name but he described it as like a sticky glue that can be troweled directly onto ‘crete before laying out matting. Has anyone used a “glue” type product under matting ?, I have previously only used thin set under matting !. Any thoughts ?!.
Tile Fix Direct
TF Official Sponsor
153
743
Aldershot
Wesley
273
East Anglia
AF200 plus it's called and not that new. Yes used it and works will. Much preferred the old AF200. I'd stick to thin set if that's what you you have used before on screed. I use the AF 200 on gypsum screeds
Thanks Julian, looking at the Ardex info it does look simple and quicker to use and only a few £’s more than usual adhesive !. Think I might give it a try for this job, just to see how how it goes. What size trowel do you use to spread the material ?, is a 4.5 x 4.5 sq notch trowel suitable ?. Thanks
J Sid
Normally comes with a spreader
Tile Fix Direct
TF Official Sponsor
153
743
Aldershot
Approximately 45m2 per 14kg tub using a B1 or 2mm x 6mm v-notch trowel
tech sheet
Reply to Matting question in the Canada Tile Advice area at TilersForums.com
I fixed some mosaic the other day, long, thin strips in a 300x300 mesh cut in to two, and used...
Hi everyone, With a kitchen renovation, Mrs choose the white mirror quartz floor tiles from a...
Wesley
East Anglia
What member type are you?
  1. Professional Wall and Floor Tiler
Matting question
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
