Discuss May As Well Fess Up To A **** Up in the Australia Tiling Forum area at TilersForums.com.
if you do not see the work you can not understand, find a good tilerWell all I can do now is remove the old stuff and refit these I thnk, whats sort of prep do you think I need to do....
What about lifting up all the tiles and then this
Bostik Cempolatex Floor Levelling Compound 25kg | Wickes.co.uk
then use the other stuff I just highlighted
GO GO GO @3_fall IS NUMBER 1You're not giving enough information I'm afraid, you won't get the correct advice if u don't.
That's why you're being advised to find someone who can take a look at it for you.
The images are not as helpful as they could be.
The PVA that u have used needs to be removed before you do anything.
Sanded off concrete, washed off tiles if poss if they're non porous.
If that is what's known as 'black' adhesive on the concrete floor u need to use product like Mapei Eco prime like has been suggested or Tilemastermaster Prime and grip. These are pre mixed slurry primers. Or u make your own with 1-1 tiling SBR and water with 30% tile adhesive, by weight.
Do you now see how complex this could be?
I'm afraid it's not just a case of slapping them down with flexi adhesive.
Sorry if this is blunt, but if u do seriously want to make headway before Tuesday this is what u are faced with.
Reply to May As Well Fess Up To A **** Up in the Australia Tiling Forum area at TilersForums.com
