Discuss Metro tiled corners, scribe in and best Silicon method? in the Canada Tile Advice area at TilersForums.com.
JMC tiling
558
hemel hempstead
Morning all,
Just wanted peoples thoughts on finishing metro tiles, specifically in the corners? Even with nice cutting you still get a diamond effect in the corners that in some cases depending on the depth difference of the metro edge can look a bit off. Do you guys scribe in to minimise this effect? also, with the Silicon finish, I use a fugi kit and consider myself a quality finisher with it but find it very difficult to use with the metro finish so was wondering what other methods people may use?
Have done plenty of metro's lately and the finish is fine but always looking to improve hence the questions.
Many thanks John.
495
1,118
Somerset
Grouting and siliconing metro tiles -
If grouting tiles using a different colour grout, I use a colour match with tile/trim to give best looking finish (e.g. white tiles with dark grey grout, use white grout between tile and trim).
Experience in corners where colour drift may occur, use same colour Silicon as colour of tile (e.g. white Silicon with white tile).
JMC tiling
558
hemel hempstead
i usually colour match the grout with the Silicon. so grey grout means grey Silicon in corners, i also use one of the smaller profiles on Silicon tool and really take my time doing it.
How do you deal with the diamond effect you get though Dave? if you Silicon in grey and you follow the tiles with a small Silicon bead in same colour, does the Silicon joint not look crooked?
dave l and l
Reply to Metro tiled corners, scribe in and best Silicon method? in the Canada Tile Advice area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Advice please on setting out bevelled metro tiles in particular situations. 1. For internal...
Hi all, Have a question about how/when best to install tile trim - probably quite basic! One...
    • Winner
Looking to do a few mitred external corners this week (600x300x9 porcelain). Practiced the cuts...
8K
hmtiling
H
Hi, We are currently in the process of having our kitchen tiled and have some concerns about...
8K
WetSaw
JMC tiling
hemel hempstead
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
