Discuss Metro tiled corners, scribe in and best Silicon method? in the Canada Tile Advice area at TilersForums.com.
JMC tiling
558
hemel hempstead
So is it just me who follows a small cut with a big cut on internal and external corners with metros?
I try to wrap it around if the cuts all work out, makes it flow much better although sometimes not possible due to setting out.
Time's Ran Out
I'd assume there are 2 ways to do them.
1. In bricklaying a full brick and a half brick.
2. In wallpapering follow the pattern around ie. into the corner with a half out of the corner with a half.
JMC tiling
558
hemel hempstead
Done this on Thursday/Friday and managed to wrap it around nicely which I reckon gives it a nicer finish. Just the white Silicon in corners to do. The diamond effect you get in corners is annoying but the white Silicon IMO does help to hide this. :wink:
MW Smith Ceramics
i usually colour match the grout with the Silicon. so grey grout means grey Silicon in corners, i also use one of the smaller profiles on Silicon tool and really take my time doing it.
Yep, I'm the same , do loads of metro white tiles and always light grey grout & I mastic internals and where tiles meet units in a grey mastic to match grout
Reply to Metro tiled corners, scribe in and best Silicon method? in the Canada Tile Advice area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Advice please on setting out bevelled metro tiles in particular situations. 1. For internal...
Hi all, Have a question about how/when best to install tile trim - probably quite basic! One...
5K
    • Winner
Looking to do a few mitred external corners this week (600x300x9 porcelain). Practiced the cuts...
8K
hmtiling
H
Hi, We are currently in the process of having our kitchen tiled and have some concerns about...
9K
WetSaw
JMC tiling
hemel hempstead
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
