View the thread, titled "Minimum charging (bathroom floors)" which is posted in Bathroom Tiling Advice on Tilers Forums.
tfs
Do any of you guys exercise a minimum charge policy when it comes to bathroom floors requiring cuts round toilets and sinks?
If so,
Can you give an idea of your min charge?
I would imagine a day rate as this is the case for design vinyl tile etc. Let me know what you think
kris
I either tell them to get plumber in to move or I'll quite happily cut around,never takes long and with plenty of practice is very neat.
Get the plumbers to do their job and they'll pass the tiling work your way.
What do you guys use to get the shape around toilet if you can't remove it.
Have got a nightmare one to finish off on Monday. Cant remove the toilet & has so far taken ages to get the cut 'perfect'. Just as I was losing the will to live with the damn thing I found the old lino that had been removed from the toilet floor & can now use that as a template. :hurray:
What other methods do people use? Solder wire? Profile tool?
Cheers
I say to my customers, you have a choice. 1, Either a plumber comes to remove/refit the sanitary ware or 2, I will be charging just as much to cut around it. In which case the removal and refit will result in a much better finish and will eliminate future problems if they have to change the sanitary ware at a later date.
Not had to cut one yet!
Grumpy
I have found that one of the easiest ways of cutting a near perfect shape around a wc pan is to use a template. To do this I suggest using wallpaper/linning paper and first cut the template to the exact size of a full tile. Then placing your template in the position that you need the cut tile, form a crease in the template around the shape of the wc pan. You can now choose to either cut this shape out of your template by using either a sharp stanley blade or scissors. Now try the template into the required position checking for accuracy and make any final adjustments to it. As long as the template fits well, the you are assured the cut tile will fit also..........It is easier to cut paper than tile. I use this method for cutting vinyl tiles such as Karndean/Amtico etc and it works for me........Try it out, good luck:thumbsup:
I think its straight forward enough to cut neatly round toilets. It only really becomes a no no when you are working with the like of 600 x 600 tiles as the pan and pedistal can be an issue with these tiles.
I would certainly much preffer to tile with the pan etc out but, I dont think all customer want this to be done.
I though it would be a good idea to see what the other guys in the forum done. I find it easy enough just to cut round with a wet saw and then usew the file to touch up some edges.
Grumpy,
In your experience does that usualy get the customer to get the plumber in?
kris
Hi,
Had some of that realy thick backing wall paper (B&Q ) and just cut to tile size.
Dry laid tiles used paper template , marked and cut tiles fitted a dream
Reply to the thread, titled "Minimum charging (bathroom floors)" which is posted in Bathroom Tiling Advice on Tilers Forums.
