mixed material installation
Hello Forum - for a lower level media room (13-ft x 30-ft), our goal is to used two (or more) tile sizes as well as a carpet tile plank in a 'Mondrian' pattern (example attached). May not stick strictly to the pattern, but it provides you with a look. Room is currently full carpet over concrete.
Assume the largest square (red in the attachment) is daltile porcelain. The black, and possibly the yellow, will be a carpet tile cut to size. Smaller rectangles will also be daltile porcelain/different color. All materials are same/very similar thickness.
Quick questions while we gather replies:
1) is an aluminum same-height trim profile (example attached) suitable for all/any part of this pattern?
2) if #1 reply is Any, can grout only be used between two tile style and alum trim otherwise? I know part of this is aesthetics, but also needing an integrity call on this approach.
3) compare the level of difficulty for the installer:
3a) grout-only and multi-size tiles - no carpet
3b) using combination grout and alum trim - no carpet
3c) difficulty for this use case, mixed material (tile and carpet) in a pattern
We've not done any DIY or hired yet for a job; also no valuable advice from the store sales staff (to be expected?) - I look forward to your expertise and any design guidance, even if it means this approach is either too difficult or unlikely to be done correctly by a contractor.
Thanks in advance!
The easiest multi-tile pattern to use is a square tile and a 'dot'.
Can you not go for something easier like this? lol
I'd choose what it is you want with the tile before you research the trim and whatnot.
But you'll be able to overcome any thicknesses in tile with adhesive (mud) etc so your choices aren't limited to the same tile manufacturer etc.
So see what pattern you're fixed with first then let us know and we'll help with the rest. 🙂
Hi Regan just wondering why you wanted to go for a combination of carpet tilies and tile and not just tile the lot? Off course it is your choice, if going for the carpet and tile combination I would tile the area first and grout, then fit the carpet tile inserts. Could always "frame" the carpet tiles with trim but not really necessary. All the best
Hi Dan -
Great points, committing to a pattern seems key. All the questions obviously come from not knowing the installation gotchas. I like the pattern you shared. One of our material choices is probably twice the length of the rectangular tile in your layout. We will play around with your idea as well as hunt for an online tool where we can insert tile sizes to arrive at a repeatable pattern. Any suggestions on a tool or site?
[automerge]1600709792[/automerge]
JK -
Appreciate the reply, we arrived at including carpet in the pattern for a myriad of reasons - not all practical I might add. The carpet is a unique boost of color we weren't finding in a tile. The carpet 'plank' is an interesting size (10in x 36in) but is making the pattern design a bit tricky. The other reason to add a bit of carpet was for some comfort for pets and foot traffic in this room. Ideally I'd like the carpet to be replaceable (much like a carpet tile) should a mess or a later design decision force us to do 100% tile eventually.
Like I posed to @Dan above, might you have a suggestion for an online tool to create patterns based on multiple tile sizes?
