Mosaic Borders/bands
I was wondering what way would you guys would price splash back panels behind sinks that stop approx 250mm from the floor and ceiling, which consist of 300x600 tiles on their side with a band of thinner mosaics which need to be screeded flush obviously with the tile, either side and the whole lot trimmed with L shape aluminium trim and then above the bath wall again 300x600 on their side but with two vertical bands of mosaic again screeded flush. All work on building sites multiple units? Any input will be appreciated, thanks.
So how did u end up pricing this Lee?
I don't wait for the adhesive to set before fitting the mosaic, I screed or "dog tooth" to a depth that allows the mosaic to be patted into the adhesive, which is a tight mix, although just wet enough to still have transfer onto the sheets of mosaic, but stiff enough to hold the weight , which to be honest isn't that much. Then if I'm honest I don't get the grouting done in that application, I carry on with other work in the house and come back to the grouting at a later stage, but the grouting of a panel only takes about five minutes anyway. I spread a bit of adhesive to the back of the trim and hold them in position with a pin at the outer edge of each corner and a couple down the length and remove them before grouting, incase you where wondering how I managed to dog tooth with trim that hasn't set.
Get a hot glue gun mate, They stick all trims first time
Hi Marc, as your aware over here we wouldn't get the same rates here as you guys would get over there from builders anyhow. The way I broke it down was £65 for a panel behind a sink and £20 per vertical border on top of the main field rate for above baths or shower trays etc. I was just keen to find out if I was far off the mark compared to what you guys would charge
Thing is, everything is relative, and as long as it pays you enough for what you need, then it's the right price! 😉
Personally, I was just looking for a thread to bump! Haha 🙄
