My bathroom project
I
Impossible
My first time tiling is coming up and it starts with my GF's 1.7x1.8m bathroom.
The place is a c1950's maisonette where all the walls are solid (no plasterboard)
I'm taking on the bathroom as part of a refresh of the place. Previously the bathroom was fitted with a iron bath, porcelain sink and toilet. Previous decor was half tiles then top half painted with a retrofitted shower.
Here are some images, this is what im working with.
http://gallery.cowbox.net/main.php?g...g2_itemId=4748
http://gallery.cowbox.net/main.php?g...g2_itemId=4751
http://gallery.cowbox.net/main.php?g...g2_itemId=4753
http://gallery.cowbox.net/main.php?g...g2_itemId=4756
http://gallery.cowbox.net/main.php?g...g2_itemId=4759
As you can see, its the original suite with a iron bath.
Shes already bought the tiles (from B&Q....... yuk) These are plane white tiles with a ripple effect on its surface (200x250x7mm) and then a boreder with these tiles...
http://gallery.cowbox.net/main.php?g...g2_itemId=4762
More images to follow.
Any suggestions on how to embed the images instead of them being links (is this due to the site they are hosted on?)
Imp​
I will always say that unless you are going to spend hours a day in the bath/shower then tanking is not needed (get your money back),tanking is a fairly new thing and the amount of tiler's i know(the list is very long)will not get involved with using it,why make a hard job more difficult ,for instance i tiled by bathroom about five years ago (no tanking)and i shower once a day and so does my wife and also my daughter has 3 to 4 baths a week and after all that usage, i have no damp ,no leakage and no discolouration of grout .
If people are wondering why they don't gety job's and are sitting at home the reason is they are pricing for thing's that are not needed.
Never ,ever make the job harder than it need's to be .
Don't see anything wrong with explaning to the customer the pros/cons of tanking. Then make it a separate item on the estimate, the customer has the choice of having it done or not. Doesn't affect the rest of the price so it shouldn't influence whether you get the job or not then.
have read all the suggestions butyou are brave ro take on such a task for your first time. your mosaic border looks like it might need to be sealed as well before fixing but that is a piece of cake. also another tip i got off the forum is to use a grout float to pad on the mosaic border, it goes on nice and easy, level and the adhesive doesn't squish through beween those wee blighters!
Thanks for this info, im new to tiling and would assume that sealing is like a varnish that stops water seeping into the tile? Would I seal the mosaic tiles before cutting and adding them to a wall? Is there just one type or sealent or shall I just take the newbie way out and take the mosaics to my local tile place and say "I would like to seal this please, what do I need?" :stupid:
OMG is that a see through bog seat?!? :lol:
Yeah, it WAS....gone in the bin now tho!
The bath took three of us to move out, so so heavy.
Thanks for the info lads, I do have some more images to upload but in work atm. Will post later.
yep seal mosaic before cutting and fixing. any tile place will sell you a bottle of sealer for anything between £10 -£25. i usually lay the sheets of mosaic out on some newspaper in a dust free environment and paint the sealer on with a small paintbrush making sure you dont overload the brush and give a second coat if you want. it dries pretty quick and always seems to change the colour of the mosaic no matter what seal i use (if white stone mosaic they seem to be off white after sealing). once they are dry, cut whatever size of strips you need for border and you are ready to use them as normal.
Hi mate,
I would suggest using plasterboard if you want to.
I would also suggest that if you are happy to pay the cash then, yes,,, tank the areas around the bath and shower (this is good practice and will be good experience for you) if I read correctly this is your own house so, time is not the biggest of factors, some tanking kits can be applied and ready for tiling within a few hourses (perhaops sooner)
I would stick the platerboard to the wall using bonding (can get it from builders merchants or even B&Q) this is just mixed with water to a thick consistnecy and applied in dots acroos the area of wall being covered with the plaster board. Use a spirit levl to ensure you push the plasterboard firmly into a plumb finnish (perhaps dot every 400mm. you can apply a little water to the wall at points where you will bond the plaster board to, to prevent the wall form sucking in all the moisture of the bonding.
when tanking with tape and compound tape all the joins of plaster board e.g. croner, tops and bottoms as well as any holes around pipes etc. reffer to instaructions and they will keep you right.
oh, and another thing............ sorry for the dodgy spelling (lol)
:lol:
if you seal with an impreganator seal before fixing tiles and then once fixed (but before grouting)
Thanks for all the advice lads, Its really helping.
I have decided to use plaster board on the top half of the wall (9mm) and use bonding to attach it to the existing plaster walls.
I had an issue where the plaster came away from the wall around the area below the shower. I have cut and applied some aqua panel to the wall (was given a sheet of it by a friend, surprised as its around £11 a sheet!) and the board needs filling around its edges. I will use flexible tile adhesive to fill the gaps and space between the original plaster wall and the new boards. Above this area the original plaster seams to bow inwards in a bowl type shape by around 1mm, I would like to try and fill this before applying the tanking kit. I assume normal finishing plaster would be fine if it was to be finished with the tanking kit?
Imp
Hi mate,
If you haven't stuck your plasterboard on yet, you could sort out the bow in the wall with bonding plaster if you have this for applying the plaster board to the wall. start applying it to the area needed and check with a feather edge to ensure a good flat finnish both verticaly and horrizontaly.
You can then apply the plaster board, ensuring that you achieve a flat, level and plumb finnish using a straight edge and spirit level.
just read your last post again mate and noticed that you mentioned there was a bow of only 1mm.
this realy is no problem unless you meant 1cm (lol)
also mate if there are any imperfections in the wall that you are going to be plasterboarding then, there is no need to sort all of these as you will finnish the plasterboard to a sufficient standard anyway. all you should check for realy is that the areas bonding plasterboard to the substrate are sound enough to hold without breaking away.
exactly m8 way over the top!!!
Sorry, I didnt make myself clear. There is a single wall where I wont be using plaster board to cover the top as the step at the bottom has fallen away when removing tiles, I have boarded this area and the original plaster above it is uneven (not broken plaster but rolling uneven surface)
I was asking for solutions to smooth/fill this area.
Imp
I think I understand now. what size is the area you patched?
is the aqua board you used sticking out beyond the rest of the wall?
read your post thouroughly this time (lol)
I would suggest follwing the methods I mentioned early using the bonding gear that you will be using to apply plaster board
The aquapanel protrudes around 1/2mm from the original plaster wall, and this plaster wall has some shallow areas, Im thinking of using finishing plaster to fill in the gaps and pull the original plaster wall upto the same depth as the aquapanel.
Red arrows show joints I need to fill the top horizontal one is 9mm in hight. The blue arrow shows the area where to aqua panel and the original plaster wall meets and the panel protrudes by 2mm. The green arrow shows the area of the wall that is bowled inwards.
Imp
I
Deleted member 1779
My bathroom project
Bathroom Tiling Advice
Unsolved
Impossible,
Impossible,
Impossible,
Impossible,
