As promised, just giving you guys a wee update on how Im finding the performance of this saw.
So far I have used the saw for some framing, skirting facings and oak flooring. The saw cuts true each time. The only issues I have had has been when I have been joining up skirting on along straight walls but this is due to timber having a slight bow rather than the saw itself. The fact that the saw tilits to both left and right has been very handy for cuting a splice when joining the two straights of skirting.
The blade I got with the saw glides through hardwoods. I installed approx 8 sqm of oak flooring and this proved to be a pice of cake and again accurate cuts every time.
I have cut some wider boards also when fitting window cills etc at around 250mm the slide mechanism is very handy for this type of stuff.
The saw has the abilty to cut up to 60 degree mitres at one side although I have not had the need to use this feature yet.
My only criticism would be that the laser pointer is way of square and I have not had the time to play about with this to try and get it true.
It is still a big heavy saw so isnt the best for small jobs but if you have a reasonable amount of cutting to do then it would be ideal. The only additional accesories I would reccomend would be a table or bench to sit the saw on and perhaps roller stands (unless you buy a table that incorporates these)
Overall I would say it is a good saw and deffo value for money. I would have no worries in reccmending this saw to anyone.
I still feel dissapointed that I didnt get the Dewalt DW717XPS but I look forward to buying this as my next saw:lol: the Dewalt would be a good buy if you can afford to spend an extra £200
