Discuss New Tilers Support - 1 in the British & UK Tiling Forum area at TilersForums.com.
Firstly the adhesive has to be suitable for porcelain ie acrylic...it should not be dotted out,especially if the walls have not been primed,usually a layer of dust prevents good contact,after a short while the tiles will de-bond from the plaster...grout will shake and the tiles will come off....Can you tell us the products you used on this job ? ..Gaz
50% coverage is ok for dry areas but for situations where wet or intermittently wet or prolonged damp conditions prevail after tiling is completed/ full coverage of adhesive,as far as practically possible,with the back of the tile and background should be acheived...backbuttering of the tile will help with this process............dave..
Was just looking for that bit. The crafty so and so's have put it in part 4!!.
I think the key thing for the query is that dot and dab is not mentioned in BS5385. It's either notched trowel method for dry areas or solidly bedded for wet/damp areas.
Reply to New Tilers Support - 1 in the British & UK Tiling Forum area at TilersForums.com
