The rubi cutter you have been looking at is a very good cutter and a lot more power than any plasplugs cutter....that rubi has a 1.2hp motor and this power is better for cutting thicker stone tiles..
And again like most rubi tools available from Tradetiler..
Rubi ND 200
http://www.**************/acatalog/nd200web.jpg
Although Rubi make some smaller flat bed saws, they are not very powerful. This is the best bet for the professional
- 40 mm depth of cut
- Stainless steel bed
- 0 - 45 deg mitre (can cut both sides of wheel)
- Sliding guide from 0 to 500 mm from wheel
- Blade guard and stem simply pull out for plunge cutting (to remove sections of the centre of a tile i.e. for sockets)
- Comes with reasonable quality diamond wheel
- Motor: 880w.....110 v or 240 v
- Wheel size - 200mm diameter 25.4mm bore
- Weight 15 Kg
The diamond wheel that is supplied with this machine is suitable for general ceramics. If you are cutting porcelain, granite marble and travertine etc then the Marcrist CK850 diamond wheel is highly recommended - See our 200mm diamond wheels section.
CHOOSE VOLTAGE BELOW
Video of ND-200 in action
