Which wet cutter to buy?
Brilliant. I have a cordless grinder. I’m thinking about getting a variable one to use for polishing. Do variable speed grinders offer any advantage when cutting? YES Do diffent tiles cut better at different speeds?YES What are the speed settings on that bosch? :grinning:
a lower speed, avoids overheating of the blade.
you will have a slower but continuous cut.
in any case, each tile is different from the other,
using it, you can understand better
I do have a variable grinder/polisher but for cutting I use a standard cordless grinder for virtually all cuts I do.
I just use a Bosch 18v Grinder.
I used a combination of blades- Montolit CGX and various Chinese blades. I don’t alter the speed depending on what I’m cutting. I use a grinder.
Some of the cheaper blades I now use mean that the Montolit have priced themselves out of the market for me. On cutting blades anyway. I’d buy another STL blade as I find it really good.
Speaking of blades, these just fell onto my doorstep as I typed!
Thanks @ATSDiamondTools for the test blades. I’ll be sure to report back.
Fitwidge,
Blunt Tool,
Fitwidge,
Blunt Tool,
