Which wet cutter to buy?
How do you find the that grinder? Works well for cutting and polishing edges?
With the right blade I was cutting 12mm thick marble, and also using a bullnose attachment as well as polishing pads to clean the edges up
Brilliant. I have a cordless grinder. I’m thinking about getting a variable one to use for polishing. Do variable speed grinders offer any advantage when cutting? Do diffent tiles cut better at different speeds? What are the speed settings on that bosch? :grinning:
I had an nd 200 and then got nd 180 the proper one not bl or anything like that because I had a bridge saw for larger tiles
Have you ever tried the little Bricollina? Best small wet saw for around the same money as the nd180 and the cleanest of them all imo
Off top my head I think it’s around 3,00-1100. Comes in handy when polishing and cleaning cuts. I was using different blades at different speeds to get good cuts on the marble.
Fitwidge,
Blunt Tool,
Fitwidge,
Blunt Tool,
